Discussion topic: Sky Q freezes and sometimes feeezes while turning purple
Message posted on 12 Oct 2025 02:44 PM
It does not matter if watching Apps or sky tv the sky q box freezes and goes off or freezes and the picture is purple and makes a humming noise. Have to switch off at the plug and restart.
Message posted on 12 Oct 2025 03:36 PM
Re: Sky Q freezes and sometimes feeezes while turning purple
Hi @McGregorc I don't believe I have ever seen a purple error screen on Sky Q. It is normally blue. Are you rebooting your TV at the same time? Are you using the Sky supplied short HDMI cable?
Message posted on 24 Oct 2025 07:17 PM
we have exactly the same and its happening more regularly - sky engineers just dismiss it - but its really frustrating"
Message posted on 24 Oct 2025 07:21 PM
Hi @McGregorc
