This discussion topic has been answered Discussion topic: Sky-Q dropping off Wifi then joining my neighbours Router
Message posted on 22 Feb 2024 07:04 AM
My Sky-Q Box is constantly dropping off my Wi-Fi which is provided by BT but then tries to join my neighbours Sky router - no Broadband access due to no password but still connects? I Then find when trying to re-pair my mini-boxes that these also try to join the same router overnight? All of my other devices have no such issue? Any ideas - really frustrating - constatntly entering my Wi-Fi SSID and password
Message posted on 22 Feb 2024 11:35 AM
@Mayes64 can I ask how you know it's your neighbours wifi have you asked them if its their SSID.
When not on Sky broadband and connecting the mini boxes by wifi the mini boxes connect to the main Q box by way of a mesh(and not to your BT router) that the main box emits this will show as a Sky SSID
Have you ever had Sky as your broadband provider
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Feb 2024 11:49 AM
Re: Sky-Q dropping off Wifi then joining my neighbours Router
Exactly what Laing said. You can rebuild your mesh from scratch to srop them from disconnecting. Go to evert minibox and turn off 2.4 ghz capacity (go on settings, press 001 then select and you'll see this setting). Once its off go to confirm and unplug minis. Go in the same menu on main box, go down to reset, chose first option,(reset settings). Box will go through a power cycle and nay disconnect from remote. If it doesn't react once it's asking you to press home when the screen goes blank, just press standby button on main box and once on press and hold 1 and 3 together on remote. You don't need to ho through the remote setup, you can just press home at this point. Go to your network settings and connect to your bt router the usual way with the password. Then turn minis on 1 by 1 starting with nearest one. If they're not connecting you can help by wps between a connected and anon connected box (only evere 2 at the same time). Minis will stay on as long as main is connected. Ignore all this if you have a sky booster
Message posted on 22 Feb 2024 12:37 PM
Message posted on 22 Feb 2024 12:47 PM
Message posted on 22 Feb 2024 12:48 PM
Essential not ensure for the Wifi Network to be connected to the Mini-boxes
Message posted on 22 Feb 2024 12:59 PM
No it shouldn't be connected to wifi network directly. They connect to the main box and that's what provides them with internet. That's why you'll see a sky ssid when lookibg at network on minis
Message posted on 22 Feb 2024 01:03 PM
@Babetta- Again - very useful information - so any connectivity issues between the minboxes and main box is only via mesh and mini-box not connected to the Wi-Fi is not a cause of this?
Message posted on 22 Feb 2024 01:08 PM
@Mayes64 correct
if minis aren't connecting to the main box (or intermitently connecting) then a booster may be needed to sit halfway between the main Q box and the mini
Message posted on 22 Feb 2024 04:37 PM
Yrs, a booster may be required but you have to be cautious with that - you cant turn 2.4 off on them so if you want one, you'll need to establish the booster as gateway device if it's in proximity of the bt router. In that case you'll need to disable 2.4 on main box too. And dont start me on bt discs. If you have them, keep them well away from sky q nodes
Message posted on 23 Feb 2024 07:49 AM
@BabettaI do have BT Mini discs - come on - spill the beans what effects do they have?
Message posted on 23 Feb 2024 10:55 AM - last edited: 23 Feb 2024 10:59 AM
@Mayes64 wrote:@Babetta- Again - very useful information - so any connectivity issues between the minboxes and main box is only via mesh and mini-box not connected to the Wi-Fi is not a cause of this?
I believe they do connect to your network to discover the Q (it spams loads of broadcast traffic out) if you use ethernet but after that (or if you are using wifi between the mini and Q), unless you are on sky broadband they only talk direct to the Q (or another mini if that's closer on wifi)
pretty sure even the streaming apps go via the Q when using ethernet but never done any traffic analysis or seen any to verify that.
Message posted on 23 Feb 2024 11:03 AM - last edited: 23 Feb 2024 11:04 AM
@Babetta wrote:Yrs, a booster may be required but you have to be cautious with that - you cant turn 2.4 off on them so if you want one, you'll need to establish the booster as gateway device if it's in proximity of the bt router. In that case you'll need to disable 2.4 on main box too. And dont start me on bt discs. If you have them, keep them well away from sky q nodes
I have my Q plugged directly into a BT disc. It always had massive problems using my mesh to get to the internet - would connect to a disc two rooms away with a rubbish signal instead of the one 5m from it - and dropping wifi was the only way to get it to behave. So mine does use the BT disc mesh but thinks it's just on ethernet.
Message posted on 25 Feb 2024 04:34 PM
Bt discs give extra opportunities for sky nodes to firm unwanted 2.4 uplinks. We don't want thst. We want all q traffic to go through the gateway box straight to main router. This is why discs should be well away from sky q nodes
Message posted on 25 Feb 2024 04:52 PM - last edited: 25 Feb 2024 04:53 PM
Sorry you've lost me a bit. What's a "gateway box"?
You mean because the sky mesh can decide it will have a mini take over the internet connection?
