Discussion topic: KELLEHER box has an orange/ amber solid light. The mini box is still working fine. I have disconnect
Message posted on 25 Feb 2024 08:44 PM
Box has solid amber light
mini box working fine
disconned and re connected many times tv says No Signal
Message posted on 25 Feb 2024 08:51 PM
Re: KELLEHER box has an orange/ amber solid light. The mini box is still working fine. I have discon
Hi @Mike11a
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
