234
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q download
Locked
This message was authored by: Richie641
Re: Sky Q download
It's a shame Sky can't ( won't ?) Put out some form of 'we know there's a problem with downloads ' message either by e mail or a news item on the Sky homepage .
This message was authored by: Kevin231
Re: Sky Q download
I have changed the dns to 1.0.0.1 and still no download. With talk talk also
This message was authored by: DavidThomson1
Is catch up on sky q down at the moment not been working for a few days
Catch up not working on bbc stv etc
Re: Sky Q download
Where did you change it? If on the Sky box did you power cycle it?
Re: Is catch up on sky q down at the moment not been working for a few days
@DavidThomson1
I have moved your post into the thread discussing this. There is a similar thread on the Sky+ board. The common link is having TalkTalk or Utility Warehouse broadband. Sky are aware.
This message was authored by: Poplil1
Re: Sky Q download
Thanks for letting us all know , I can stop trying now , it's been driving me bonkers 😂
Re: Sky Q download
Yes did a full reboot
Re: Sky Q download
Maybe you are one of those who it seems benefit from turning off that "advanced security" setting on the eero router.  Seems to be blocking some Sky content by mistake.
if you do and it works, I would probably turn it back on once this is all resolved, it probably protects from things like known phishing sites
Re: Downloading
Thanks for your help 😂😂😂🤦🏼‍♀️😂
This message was authored by: Katkin85
Re: Sky Q download
I've just discovered this thread after unsuccessfully trying to download programmes after the last few days! However, my broadband is with Sky not TalkTalk...anyone have a solution as to what I can do? Its really frustrating - syrely
This message was authored by: Deet
Re: Sky Q download
After changing my eero dns address last night (sky qbox then also showed this number) I've now discovered that the Sky box's dns today says 192.168.4.1 & guess what, nondownloads.
went into the eero router & turned off "advanced security" & "ad blocking" & download instantly resumed.
This message was authored by: ColWay
Re: Sky Q downloads disabled?
Same problem here for the last couple of days and my broadband provider is Talktalk. Just changed the DNS setting to 1 0 0 1 as recommended on here and it's all started working again now! Thank you! 👍
Re: Sky Q download
the dns showing in advanced settings on my sky q box has now reverted to 1.0.0.1 since turning off advanced security & ad blocking.
This message was authored by: G.reg
Re: Sky Q download
No problem...I see a few on this thread have said they have changed the DNS settings (whatever they are ?)and they can now download but Sky have told me to do nothing as the issue will be resolved by the weekend...
This message was authored by: Stephanie1012
Re: Sky Q download
many thanks. Been without downloads for five days,.   sky said it would've been fixed by last night, but it wasn't.   changed to 1 1 1 1 and works perfectly.   our Broadband is with Talk Talk Business.  didn't change any router settings.   spent ages on the phone to Talk Talk and sky this week.  why couldn't they just advise to change the DNS?   thank you for your post
Locked
Answered - Go to Answer
