234
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q download
Locked
This message was authored by: Wibbly-Woo
Re: Unable to download Flipping Bangers series 2 - on Q
@Daniel0210
Where is the link to the fix ?
You told me that my post had been moved - to where ?
I am confused - it looks as if my whole post has been moved and combined with another similar post - mentioning DNS being changed ?
Come on - how am I supposed to change my DNS and why ?
@Wibbly-Woo wrote:
@Daniel0210
See the post currently marked as the answer
To the thread it's now in that's discussing the issue you have
Re: Sky Q download
@Abdnpete
Same question from another disabled person
@Wibbly-Woo wrote:
@Daniel0210
There are detailed explanations throughout this thread, which your post has been merged into, about how to do it.
why - because TalkTalk's DNS is messing up your Sky downloads. You only have to change it on the Sky box.
I am not happy messing with previously good DSN settings
What can be done about this ?
Can't sky send updates out ?
OK Give me step by step instructions
No it's TalkTalk's fault, not Sky's. They can work behind the scenes to get it resolved but they can't just send out an update.
Don't worry about messing this up, it's an easy, non-destructive change you can modify again as many times as you need to. See the other thread for step by step instructions.
This message was authored by: Gav+J
Re: Sky Q download
I thought I'd come here and found the solution to my problem but even after changing the eero dns (I did 1.0.0.1 and 8.8.8.8) and having the dns on the sky box set to the automatic one and then also changing to 1.0.0.1 my downloads are still not moving off 0%.
Have fully powered down the sky q and obvs the network restarted after the change
I've no queued downloads and have deleted everything from the deleted folder but still no joy.
anyone have any ideas on what else I can try ??
thanks
Re: Sky Q download
thanks
Has that 1.0.0.1 on the Q box stuck? Does it still say that?
if so, might be a different issue. Are you with TalkTalk?
Re: Sky Q download
It did yeah ... I've since changed it back to the 192 address it was on before
yeah talktalk 900 with eero pro 6's
as mentioned by other people the likes of iPlayer work on the box so does seem like it's summet to do with this dns issue
Re: Sky Q download
Tried turning off that "advanced security" option mentioned in this thread?
Re: Sky Q download
Yeah had to do that to be able to customise the dns in the eero app
I'll keep trying to see if I can get lucky with a setting and it kicks in
thanks
Re: Sky Q download
It's working !!
changed the secondary to 1.1.1.1 but also then left off the advanced security after Chodleys reply so will try turning that back on after this download has finished and see if it was the secondary or the security blocks
thanks for the replies !!
@Chodley
Which "other" thread ?
I have found the DNS and mine is set to 79.79.79.79
What should I set it to ?
@Wibbly-Woo The other one that I replied to you in that is discussing the general download issue (oh it's this thread, it got merged sorry, the way the forum titles its notifications ignores that so it looked like we were still talking in "flipping bangers"!)
but now you are there - change that to 1.1.1.1 and save / confirm it
is that on your Q box or router?
if on the Q box, apparently you need to power cycle it at the wall for that to take effect.
Thank you
That works but I am now having problems logging on to this forum on my PC
  • This was posted from my mobile phone
I am now able to log in on my PC as well - I guess that it must be down to numbers of people trying to log in ....?
Locked
Answered - Go to Answer
