5
This discussion topic has been answered Discussion topic: Sky Q deactivated
This message was authored by: JAMES552
Sky Q deactivated
Hi. I got a Sky Glass TV and they appear to have deactiavted my Sky Q. Is this normal
This message was authored by: SKY1992bf Answer
Re: Sky Q deactivated
@JAMES552  Yes has you can't have both on the same account it's one or the other
you will be sent return instructions for your Q hardware when you are near the end of your glass cooling off period
Avatar for JAMES552
Thanks. They never explained that it wold be disabled at the tiime albeit they have been looking for it back and have charged me for not returning it. Why can you not have both
@JAMES552  Because sky doesn't allow more than one tv product per household
if you have been asked to return the Q hardware you are contractually obliged to do so and obtain proof of postage
once returned after about 8 weeks you can call sky tell them about your proof of postage and they should refund the non return charge
There's no technical reason, but Sky has never permitted subscription platforms to be mixed.  In addition, Glass/Stream will effectively be the successor product to Q once satellite television transmission ceases in a few years time.
Avatar for JAMES552
Thanks. Pity the puck doesn't record especially BBC and you cant work it from the app like Sky Q
