7
This discussion topic has been answered Discussion topic: Sky Q crashes when paused
This message was authored by: matrix26
I had Sky Q installed 36hours ago.
Since then whenever I pause a show, either live TV or a recording, the box freezes and makes a loud whining noise.
I then need to unplug the box and plug it back in again.
Is my box faulty?
Re: Sky Q crashes when paused
Is my box faulty?
Hi @matrix26
Avatar for matrix26
Is my box faulty?
I should add that I only have the main Sky Q box and no mini box
Imma say yes, sounds like a flakey hard drive imho, but worth trying a reset on the hidden installer menu.
Is my box faulty?
Hi @matrix26
Avatar for matrix26
Thanks.
Will the reset stop the sky Q controller working on my TV?
@matrix26 wrote:
Thanks.
Hi @matrix26
Yes but you re pair it as per my post
Avatar for matrix26
Ah, ok.
Didn't realise the sky controller was connected via Bluetooth.
Thanks.
I'll give the reset a go once my latest show has ended.
Roughly 15 mins
Avatar for matrix26
Many thanks to you both.
The reset seems to have done the trick.
Have a great time over the upcoming holidays
