This discussion topic has been answered Discussion topic: Sky Q crashes when paused
Message posted on 29 Nov 2023 09:11 PM
I had Sky Q installed 36hours ago.
Since then whenever I pause a show, either live TV or a recording, the box freezes and makes a loud whining noise.
I then need to unplug the box and plug it back in again.
Is my box faulty?
Message posted on 29 Nov 2023 09:33 PM
Is my box faulty?
Hi @matrix26
Message posted on 29 Nov 2023 09:22 PM
Re: Sky Q crashes when paused
@matrix26 wrote:I had Sky Q installed 36hours ago.
Is my box faulty?
I should add that I only have the main Sky Q box and no mini box
Message posted on 29 Nov 2023 09:32 PM
Imma say yes, sounds like a flakey hard drive imho, but worth trying a reset on the hidden installer menu.
Is my box faulty?
Hi @matrix26
Message posted on 29 Nov 2023 09:37 PM
Thanks.
Will the reset stop the sky Q controller working on my TV?
Message posted on 29 Nov 2023 09:40 PM
Message posted on 29 Nov 2023 09:43 PM
Ah, ok.
Didn't realise the sky controller was connected via Bluetooth.
Thanks.
I'll give the reset a go once my latest show has ended.
Roughly 15 mins
Message posted on 30 Nov 2023 02:18 PM
Many thanks to you both.
The reset seems to have done the trick.
Have a great time over the upcoming holidays
