Discussion topic: Sky Q connection issues.
Sky Q Mini box is struggling to connect to Sky Q box in our new extension. It works for a small amount of time and then the connection to the Main Sky Q box drops.
Internet connection to our Virgin router also drops.
the sky Q box is only 4 metres from where it used to be. It used to work with no issues.
there are no WiFi issues in the extension..
Re: Sky Q connection issues.
The Q boxes don't use your WiFi to connect.  (They use their own private mesh)
If you've moved it 4 metres then that's probably why it's no longer working...
Sky can provide booster if you call them.
hi @Anonymous
Reboot the mini as above.
