Discussion topic: Sky remote won’t work on sky Q box but will work on Sky min box
This message was authored by: Arkblue
Remote will not work on main box but will on mini box. 3 seperate controls will work on mini box but not main sky Q box
Re: Sky remote won’t work on sky Q box but will work on Sky min box
Hi @Arkblue
Depends if you are pairing the remotes correctly.
If paired with a Q box by Bluetooth then Q remotes will only work with the paired Q box.
However in infrared mode Q boxes will work any Q box using infrared.
You need to completely reset a remote and then pair it to Q box and TV.   TV control is by Infrared only with a Q remote and once paired will work any TV with the same brand but only work the paired Q box (assuming it has been correctly paired to the box)
If you have difficulty pairing any Q remote try rebooting the Q box before pairing.
If trying to pair more than one Bluetooth remote to a Q box the last subsequent paired remote will override previous pairings.
To reboot Q boxes before pairing press Standby on your Sky Q remote (if the box responds to the remote), and then switch off and unplug at the mains.
Completly reset your Bluetooth remote and repair as follows.
