Discussion topic: Sky Q cannot connect to internet.
Message posted on 09 Sep 2024 03:27 PM
Having trouble with Sky Q box saying trouble connecting to internet. Also mini sky box is saying trouble connecting to Sky Q.
Message posted on 09 Sep 2024 03:34 PM
Re: Sky Q cannot connect to internet.
Hi @Tkendrick27
