Discussion topic: No satalight signal sky dish moved in wind
Message posted on 09 Sep 2024 05:09 PM
No sky signal on chanel 2,3 & 4
Message posted on 09 Sep 2024 05:12 PM
Re: No satalight signal sky dish moved in wind
Hi @Karen6819
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 09 Sep 2024 05:13 PM
@Karen6819
Presume those are your 'favourite' channels?
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
