8
This discussion topic has been answered Discussion topic: Sky Q box
This message was authored by: Bogtrotter45
Sky Q box
I'm a returning customer and I'd like to order a sky q box. How can I do it.
The chat it was useless
Re: Sky Q box
@Bogtrotter45
Using the above links, and having changed the flag in the bottom right corner to the ROI flag should lead to a 0818 number.
Re: Sky Q box
You're probably best off ringing Sky.
Avatar for Bogtrotter45
Re: Sky Q box
Thanks for your reply.
Is there a number to ring? The only number I've seen has a connection charge and a per minute charge too
Re: Sky Q box
@Bogtrotter45
These are the current methods for contacting Sky. Depending on the reason for making contact some methods will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Re: Sky Q box
Thanks for all that information. I'd really like to talk to a human about my requirements but I don't have sky mobile or, currently, have sky broadband. I am in ROI
Re: Sky Q box
@Bogtrotter45
This message was authored by: Ramesh2
Re: Sky Q box
Please let me know which address I should send the Sky device box to.
I do not want the Sky device and I am requesting a return and refund.
The device has not been used and is in perfect condition.
Please share the return address for the Sky device.
I do not want it and request a refund.
Re: Sky Q box
@Ramesh2
I'm presuming that you wish to return a Sky Q box as you've added to this thread. Why has it not been used?
This message was authored by: Ag991
Re: Sky Q box
Don't bother! Been off all day and the lines are so busy they don't answer. Followed all instructions and the pile of **bleep** is useless. Keep telling us we're VIP customers well not today clearly. £139 per month for nothing.😡🤬
Answered - Go to Answer
