Discussion topic: Sky Q box wouldn’t start.
Message posted on 12 Mar 2024 09:52 AM
There is power to the box, but it won't start and the tv doesn't read it.
Message posted on 12 Mar 2024 10:05 AM
Re: Sky Q box wouldn’t start.
I have had issues with the last 2 updates
End up doing a full software reload seemed to cure the problem
Message posted on 12 Mar 2024 10:18 AM
Hi @Mohamed01
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
