Discussion topic: Sky Q box won’t work
Message posted on 24 Jul 2023 07:24 PM
Need help with a Q box, no blue light but internet on, nothing coming on tv screen. I've unplugged it twice for 15min and followed the steps to reset but no joy. Called sky and was on a call for 38mins only to be upsold another box free
of charge but upgraded package free for two months! Not best pleased as been a customer for 17 years! Any help would be very much appreciated.
Message posted on 24 Jul 2023 07:26 PM
Re: Sky Q box won’t work
Hi @Eloise1905
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 24 Jul 2023 08:22 PM
Thanks, I decided to call again and got through to a brilliant chap who helped.
