Discussion topic: Sky Q won’t record
Message posted on 24 Jul 2023 08:34 PM
Sky Q won’t record
Sky Q box refuses to download or record programs. Just states download failed - technical fault
I've tried resetting, but I think it maybe a hard drive failure.
Message posted on 24 Jul 2023 08:39 PM - last edited: 24 Jul 2023 08:39 PM
Re: Sky Q won’t record
Hi @TonyP1964
Was it just a reboot you tried?
If so try a Reset Settings in the Q box hidden menu.
Message posted on 24 Jul 2023 08:47 PM
Yes I did the reset from the hidden menu but no change sadly
Message posted on 24 Jul 2023 08:50 PM
Looks terminal unfortunately @TonyP1964
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 24 Jul 2023 08:54 PM
The wife will be **bleep**! I'm about to delete all her programs!
thanks
