Discussion topic: Sky Q box voice control
Message posted on 07 Nov 2024 08:22 PM
Why won't my sky remotes voice control work
Message posted on 07 Nov 2024 08:26 PM
Re: Sky Q box voice control
hi @jerry1049
What is happenng when yo utry Voice control ?
To use Voice control the remote must be paired in bluetooth mode with the box
If you need to re-pair then then may I suggest you try a reset of your remote first:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 10 Nov 2024 01:03 AM
Everything you are suggesting I have done. Many times. I'm looking for something different to try. I have done the engineers menu and done a reset but not total reset as I dint want to lose my current recording. Surely Sky are aware of this problem what is their official line?
