Discussion topic: Sky Q box turns off while watching program
Message posted on 10 Nov 2023 08:35 PM
Message posted on 10 Nov 2023 08:45 PM - last edited: 10 Nov 2023 08:46 PM
Re: Sky Q box turns off while watching program
Are you sure it is your Q box and not the Eco settings on your TV set.
If you are sure it is your Q box check if it is getting too warm.
Make sure it has adequate ventilation and is not stacked with other devices.
Also Check your Q box Standby settings. In Eco and Active the Q box will go into stanby after a period of inactivity (Ie no remote operations)
https://www.sky.com/help/articles/using-the-standby-settings
Message posted on 12 Nov 2023 08:10 AM
Hi,
Thank you for the information and have tried all the things you said to do, but still keeps happening, I had this box replaced a couple of weeks ago, so I could have HDR because the other box compatible
Message posted on 12 Nov 2023 10:38 AM
Hi,
As it is a relatively new box @sparkysparks
have you checked that the Software is up to date?
https://www.sky.com/help/articles/sky-software-updates
