Discussion topic: Sky Q box start up issues
Message posted on 03 Oct 2025 10:16 AM
- Sky Q box start up issues every morning, Black screen tells me to push home button when screen goes blank, this will only take a couple of minutes.
Tried to change standby mode from eco to normal and to none but still no joy
Message posted on 03 Oct 2025 10:38 AM
Re: Sky Q box start up issues
Hi @Dmax
Assume that you are leaving the Q box in standby overnight and not completely switching it off at the mains.
