Discussion topic: Sky Q box not working after nighttime
This message was authored by: MaryLM
For over a week and on numerous occasions before this, I have had to unplug and reset my Sky Q box to get it working every morning. After nighttime and iy not being used for a number of hours, my Sky Q box does not respond to the remote or the box buttons. I have had to unplug and reset, which then works for the rest of the day. This is fine, however having to do a reset on it every morning surely isn't normal??? Considering I didn't have this problem before 🤔
Re: Sky Q box not working after nighttime
Hi @MaryLM
Try a Reset Settings in the Q box hidden menu.   See if that helps.
