Discussion topic: Sky Q box not pausing
Message posted on 18 Jun 2025 02:23 PM
We needed to disconnect our Sky Q and tv to move them and have now put them back after 18 hours but now we cant pause programmes. Have tried unplugging and re setting but still doesnt work.
Message posted on 18 Jun 2025 03:00 PM
Re: Sky Q box not pausing
Did you carry out a reset settings in the hidden menu @Jan600
