Discussion topic: Sky Q box not not connecting to the internet
Message posted on 21 Jul 2024 12:28 PM
Our sky Q box has been frequently dropping internet connection and now won't connect at all since upgrading to superfast broadband. We've tried turning off at the mains, resetting the router but it seems to connect for a minute or two then drop again. It's driving me nuts! WiFi speeds are excellent. It seems to be entirely related to the box as the tv itself is still connected to the internet. Any advice very gratefully received!
Message posted on 21 Jul 2024 01:52 PM
Re: Sky Q box not not connecting to the internet
I had this for months 3 engineers later still **bleep**ed !!! I moving to a different cheaper company
Message posted on 21 Jul 2024 04:54 PM
Hi @Therah
