Discussion topic: Sky Q box not downloading
Message posted on 01 Aug 2024 06:09 PM
Recently upgraded to the Sky Q 2tb UHD box and nothing is downloading always stuck on 0% and netflix also does not work keeps saying 'Sorry, this app is currently unavailable. Please try again later' had the box for two weeks and still facing this issue.
Message posted on 01 Aug 2024 06:28 PM
Re: Sky Q box not downloading
Hi @Bal2
Message posted on 01 Aug 2024 07:05 PM
Just tried this still not working, also tried to update the box. FYI only the YouTube app works so don't think internet is the issue
Message posted on 01 Aug 2024 07:42 PM
Hi @Bal2
You only need to update the box if it not on the latest version.
Bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
See following links for latest Software versions
https://www.sky.com/help/articles/sky-software-updates.
Have you tried a Reset Settings in the Q box hidden menu.
Message posted on 02 Aug 2024 10:54 AM
I tried this, still not working
