Discussion topic: Mini box won't connect to main box
This message was authored by: Gerry.Petticrew
I have sky q with 2 mini boxs 1 off the boxs won't connect to the main box .
1) I have tried reinstate : no joy
2) I have moved it closer to the main box: still nothing.
3 ) I have rebooted the whole system.: still nothing.
I have a Network connection on the mini box.
Re: Mini box won't connect to main box
Hi @Gerry.Petticrew
Reboot the minis as above.
If a mini still does not connect reliably try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
To clarify; switch off both the main box and the Minis at the plug. Wait a minute before restarting the main box, and then wait,until it has fully restarted before turning on the Minis.
Avatar for Gerry.Petticrew
Sorry still nothing exactly as is .
I'm slowly losing the will to live.
Hi @Gerry.Petticrew
Have you tried swapping the two minis over to see if the problem one will work at the other mini location?
Yes this was the first thing I done.
I've got it working.
I reset the network connection (even though it was telling me it was connected) then I wps the main box and the mini and it worked great.
So hopefully I'll have a happy wife lol
Thanks for the follow up message it's good to know that someone else was feeling my pain
As advised in my first post @Gerry.Petticrew
