Discussion topic: Sky Q box not connecting to router
Message posted on 12 Nov 2023 11:22 AM
Sky Q box will no longer connect to the router. I have tried the wps button, tried manual connect. I have not love the any equipment. The Wi-Fi is working for other non-sky devices.
Message posted on 12 Nov 2023 11:41 AM
Re: Sky Q box not connecting to router
Hi @Joe86
Try first rebooting the router.
Disconnect power lead for 30 sec and then reconnect to reboot.
Wait until the router is completely back up and running and then try the Network reset on the Q box again.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 27 Oct 2024 11:51 AM
Av tried all that but just keeps comming up unsuccessful
