2
This discussion topic has been answered Discussion topic: Connect Sky mini boxes to non Sky broadband
This message was authored by: barneyman2002
Hi,
my current set up is Sky Q wired as well as one of the mini boxes, with the second mini box using wifi - it is on the same floor as the router so normally connects ok - though we did have fun with xmas lights causing an issue but thats another story!
As we are a three storey townhouse i also have a ubiquiti box on the middle floor which basically provides the wifi for tablets and phones etc.
Anyway, i am thinking of moving to Plus.net Full fibre 900mbs - as its a bit cheaper - so wanted to check connecting that mini box to a plus.net wifi rather than sky wont present any issues.
Also, was there any other considerations i not to take into account when moving from sky broadband?
Much appreciated!
This message was authored by: nigea99 Answer
Re: Connect Sky mini boxes to non Sky broadband
@barneyman2002 wrote:
Hi,
Much appreciated!
hi @barneyman2002
SKY Mini boxes will not connect to 3rd party wifi.
If you change from SKY then the minis using wifi will use a wifi signal generated by the Main Q box
Hi,
Much appreciated!
hi @barneyman2002
Avatar for barneyman2002
Level 2 icon
thanks for that...
not really a way to est that beforehand really either?
maybe i just get that box/tv wired and then i am not effectively tied to sky going forward
Answered - Go to Answer
