2
This discussion topic has been answered Discussion topic: Sky mini box not connecting
This message was authored by: Soph5
Re: Sky mini box not connecting
Hi @Soph5
Reboot the mini as above.
Hi @Soph5
This message was authored by: Tagbo
It connects each time and then drops after 5 mins.
Terrible that no one avialble at SKY. Theie service leaves a lot to be desired. That is as diplomatically as i can put it. Expletives would describe my thoughts more accurately.
