Discussion topic: Sky Q box not activating!
This message was authored by: Couble
Sky Q box working this morning , however, despite new batteries in remote, Q box remains dormant showing only weak orange light - no signs of life / no red light. TV on showing "no signal" on screen..
This message was authored by: Deedee36
Re: Sky Q box not activating!
Hi @Couble have you tried a reboot off your system?
“Trying to help improve sky glass”
@Couble if a reboot as suggested by @Deedee36 doesn't work try unplugging the box for 20 minutes then plugging it back in
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Couble   Try resetting your remote by holding down 7 & 9. It should then work with direct line of sight to the box. Then re-pair it to your TV by holding down 1 & 3.
https://www.sky.com/help/articles/setting-up-q-remote
