Discussion topic: Sky Q box (non iPlayer UHD)
Message posted on 05 Dec 2024 09:03 AM - last edited: 05 Dec 2024 09:07 AM
I recently asked Sky to exchange my 2TB Sky Q box (UHD but not HDR) for one with UHD and HDR compatible., and I requested the latest version box.
However they sent the version box with own power supply but i understand this version doesn't do BBC iPlayer in UHD, mine certainly doesn't.
Can someone confirm this please before I contact Sky requesting a swap. .
Message posted on 05 Dec 2024 09:38 AM - last edited: 05 Dec 2024 09:50 AM
Re: Sky Q box (non iPlayer UHD)
hi @Big+Stevie
The V2 box you have Hardware version 32B1xxx with a separate Power supply does not support the UHD version of iPlayer (we don't really know the full reason for this)
SKY do not guarantee any specific version of HDR boxes. As you don't own them then you really don't have specific levers to demand a specific version as both the V2 & V3 support the UHD/HDR which your subscription covers
From another discusion I note you have a Panasonic 4K OLED TV - quite frankly I would not hold out/push for a SKY box that supports iPlayer when your TV has a UHD Version of iPlayer that will be better
We generally suggest using apps on the TV or other devices such as Firesticks and Apple TV boxes as these are far more likely to have better versions of the apps .
Personally I never use the apps on Q except for testing somthing
All SKY Q boxes are now several years old and many people like yourself will have newer Tech better placed for supporting the apps.
In reality SKY Q apps are just a convenience & a way of SKY trying to provide a one stop experience.
BTW I Have had a V2 box for nearly 3 years now and quite happy with it
Message posted on 05 Dec 2024 09:51 AM
Hi @Big+Stevie As far as I can see there are no new 32B2xx 2 TB boxes. They have only been supplying 32B2xx 1 TB boxes for ages. You could always downgrade to 1 TB if you particularly want BBC iPlayer UHD. However, why would you want that if your TV already has it.
Message posted on 05 Dec 2024 10:26 AM
Thanks, i accept that my TV does things better than the Sky box but was hoping the new box would present iPlayer in UHD.
if their latest box is only 1TB then I'll stick with what I have, but a 2TB box that does iPlayer UHD would be ideal to get full moneys worth
