Discussion topic: Sky Q box losing internet connection
This message was authored by: Trinichief
The sky Q box keeps disconnecting from internet while it is connected to network, several times today.
Re: Sky Q box losing internet connection
Have you tried completly resetting the connection @Trinichief
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Trinichief
Yes, we have tried rebooting both the sky box and the 3rd party router with no solution to the issue. All our other devices experience no issues with connecting to the internet. The box shows connected to the network without internet connection.
Hi @Trinichief
A network reset isn't a reboot
