5
This discussion topic has been answered Discussion topic: Mini box connection problem
This message was authored by: Sarah1124
Every time put tv on comes up with a black screen with you can't watch tv S there is a connection problem
only way to fix it is to unplug and reboot
we must do this 5 times a day how can this be fixed
Avatar for Sarah1124
This message was authored by: Sarah1124 Answer
Re: Mini box connection problem
It was in eco standby mode
returned to active no longer does this connection problem
thanks
Hi @Sarah1124
Reboot the mini as above.
thanks
This message was authored by: tony+george+baker
My problem in trying to get the mini boxes to join the network is that I cannot even turn the mini boxes on. The red light does not change and therefore I am unable to go to mini box setup to try the many answers given in the Sky help forum.
@tony+george+baker what happens if you press the on button on the mini box. Incase you don't realise the red light is also the on button
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Nothing the red stays red and I did know it was the on/off button.
