Discussion topic: Sky Q box keeps unpausing despite rebooting
This message was authored by lowbug This message was authored by: lowbug
Rebooted it, brand new install keep unpausing itself, can't rewind no customer service
Re: Sky Q box keeps unpausing despite rebooting
Hi @lowbug
lowbug
Thanks, we tried this twice.
it still does it. Brand new box and the 10+ year old box it replaced was better in every way...
