Discussion topic: every time I switch on Sky Q says it will not connect to router/
Message posted on 15 Mar 2024 02:39 PM
every day It says not connected to Router therefore have to re-enter password why?
Message posted on 15 Mar 2024 04:36 PM
Re: every time I switch on Sky Q says it will not connect to router/
Hi @Richard524
Message posted on 15 Mar 2024 06:51 PM
Hi I have got the same problem since sat , rang sky was on fone for 45 mins , sorted it out 1 hr later had to get back onto sky same problem, once again sorted out, when tv switched off over night next morning same problem every morning since , been back onto sky tonight for an hr same problem so send engineer mon, apparently lots others having same problem since they have done their latest software update
