Discussion topic: Sky Q box keeps unpausing despite rebooting
This message was authored by: lowbug
Rebooted it, brand new install keep unpausing itself, can't rewind no customer service
Re: Sky Q box keeps unpausing despite rebooting
Hi @lowbug
Avatar for lowbug
Thanks, we tried this twice.
it still does it. Brand new box and the 10+ year old box it replaced was better in every way...
Avatar for lowbug
Sky support is rubbish. Lie to you telling you they sent a fix to it. The old box was better.
how do we cancel the contract?
Avatar for lowbug
Still no support. I'm cancelling.
