Discussion topic: Sky Q box keeps switching itself off?
Message posted on 19 Jun 2023 08:46 PM
When watching tv on sky q box whether it's live tv or from something I've recorded the screen goes blank and the box switches off. Any ideas why this is happening plz TIA
Message posted on 19 Jun 2023 08:48 PM
Re: Sky Q box keeps switching itself off?
Hi @Mich4F
Is the Q box well ventilated and not stacked with other devices. Is looks like it may be overheating.
If this isn't the issue
Message posted on 19 Jun 2023 08:58 PM
Thank you it is definitely not over heating as it's well ventilated. I have done the reset you suggested so hopefully this works. Thank you
Message posted on 27 Oct 2023 06:17 PM
I'm getting this problem. Tried resetting the box, but it's still hapenning. Any more ideas?
Message posted on 19 Dec 2023 04:16 AM
You are asleep. Otherwise you will see notice off box off soon to save energy
Message posted on 22 Feb 2024 10:35 AM
Every time I switch my tv off my sky q box switches itself off. Any idea on how to fix this please
Message posted on 22 Feb 2024 10:42 AM
@drummer12 wrote:Every time I switch my tv off my sky q box switches itself off. Any idea on how to fix this please
That's the new smart standby feature. There's not much point leaving the Sky Q box on when the TV is off (it will still record etc in standby mode) but if you wish to disable this anyway, go to Settings, Setup, Preferences, set Smart Standby Mode to off.
Message posted on 22 Feb 2024 10:55 AM
New feature. Note that the Sky Q box is not "switching off", it is going into standby
Message posted on 22 Feb 2024 10:57 AM
Thank you will try it later.
Message posted on 22 Feb 2024 11:39 AM
@drummer12 as @Invisiblename say this is the new smart stanby feature introduced in the new Q250 software update if you don't want this to happen you can turn it off by doing the following
press the home button scroll down to settings then setup then preferences then smart standby and turn it off
Message posted on 10 Apr 2024 11:30 AM
I think there is a point in having the Q box on when the TV is off. I have just got a new Q box and everytime I switch off the TV the box goes off which I am finding very frustrating (I am going to change this thanks to these Sky community posts).
For example, if I plan to watch the news at 6pm and have the box showing BBC, and then switch off the TV as say 5.30, if the box is still on and I don't quite make it to the TV by 6 I can switch on the TV and rewind to the beginning of the News programme so I have missed nothing. Of course this applies to any programme.
Message posted on 21 Apr 2024 03:28 AM
Does t work don't bother
Message posted on 29 Nov 2024 08:02 PM
Yes I'm having the same problem. Sky qbox randomly just switching off whilst watching. Has happened 4 times this week.
Message posted on 01 Dec 2024 06:10 PM
My sky box keeps turning off while I'm actively watching TV. Is this really caused by some software update introducing a "smart standby" feature or is it something else?
Message posted on 09 Dec 2024 10:07 PM
Same here. Has happened several times this evening. Before only a couple of times over the last couple of weeks. It is getting annoying.
