Discussion topic: Sky Q box keeps switching itself off?
This message was authored by: Mich4F
When watching tv on sky q box whether it's live tv or from something I've recorded the screen goes blank and the box switches off. Any ideas why this is happening plz TIA
Re: Sky Q box keeps switching itself off?
Hi @Mich4F
Is the Q box well ventilated and not stacked with other devices.   Is looks like it may be overheating.
If this isn't the issue
Avatar for Mich4F
Level 0 icon
Thank you it is definitely not over heating as it's well ventilated. I have done the reset you suggested so hopefully this works. Thank you
This message was authored by: WeeAl57
I'm getting this problem. Tried resetting the box, but it's still hapenning. Any more ideas?
This message was authored by: ElevenSeven
You are asleep.  Otherwise you will see notice off box off soon to save energy
This message was authored by: drummer12
Every time I switch my tv off my sky q box switches itself off. Any idea on how to fix this please
That's the new smart standby feature. There's not much point leaving the Sky Q box on when the TV is off (it will still record etc in standby mode) but if you wish to disable this anyway, go to Settings, Setup, Preferences, set Smart Standby Mode to off.
This message was authored by: Invisiblename
New feature. Note that the Sky Q box is not "switching off", it is going into standby
I am just another Sky customer!
@xenon81
Thank you will try it later.
@drummer12 as @Invisiblename say this is the new smart stanby feature introduced in the new Q250 software update if you don't want this to happen you can turn it off by doing the following
press the home button scroll down to settings then setup then preferences then smart standby and turn it off
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
This message was authored by: South+Toony
I think there is a point in having the Q box on when the TV is off.  I have just got a new Q box and everytime I switch off the TV the box goes off which I am finding very frustrating (I am going to change this thanks to these Sky community posts).
For example, if I plan to watch the news at 6pm and have the box showing BBC, and then switch off the TV as say 5.30, if the box is still on and I don't quite make it to the TV by 6 I can switch on the TV and rewind to the beginning of the News programme so I have missed nothing.  Of course this applies to any programme.
This message was authored by: Djsteve
Does t work don't bother
This message was authored by: Carmel25
Yes I'm having the same problem. Sky qbox randomly just switching off whilst watching. Has happened 4 times this week.
This message was authored by: TDME
My sky box keeps turning off while I'm actively watching TV.  Is this really caused by some software update introducing a "smart standby" feature or is it something else?
This message was authored by: Roginlon
Same here. Has happened several times this evening. Before only a couple of times over the last couple of weeks.  It is getting annoying.
