Discussion topic: Sky Q box keeps crashing
Message posted on 24 Jun 2025 09:07 PM
Sky q box 3 years old, keeps freezing, have to power off and restart every time, happening every day/every other day. Not in a position to overheat, however does get noisy a lot. Sometimes when it crashes screen goes green, sometimes completely pink? Remote just stops working, however the remote is working so the box isn't getting the signal. When I restart the box it runs ok until it happens again?
Message posted on 24 Jun 2025 09:20 PM
Re: Sky Q box keeps crashing
Nothing to do with Age of Q box @Sarah1121
No new Q boxes have been manufactured for a lot longer than 3 years and the many millions in use are recycled for exchange and repair.
