Discussion topic: Christine
Message posted on 24 Jun 2025 11:04 PM
Christine
No satalit
Message posted on 25 Jun 2025 12:09 AM
Re: Christine
It was very windy today, your dish might have moved
i would try a power off and back on at the wall first though.
and then you can use this troueshooter. Might end up needing a technician visit.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-check-q
Message posted on 25 Jun 2025 04:45 AM
Re: Christine
@ChristineWest wrote:
No satalit
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
