Discussion topic: Sky Q box issues - freezing
This message was authored by: Milo1960
My sky q main box keeps doing these thing several times a day:-
1. freezing ( the most common fault happening)
2. the remote  stops working
3. message saying - there is a technical fault with this channel.
4. Programs set to record fail. Saying it's due to a power cut, which isn't the case electricity supply wise.
If I turn the power to the SkyQ box off,  it restarts and for a while all is ok.
I have reset the box by going to settings using 001 and resetting but this has not helped.
what now ?
This message was authored by: Cheryldavies328
Re: Sky Q box issues - freezing
It's saying this channel affected by a problem with your satellite signal
Avatar for Milo1960
No.  Box just keeps freezing is the main problem.
