Discussion topic: Sky Q box freeze
This message was authored by: CWH
Sky Q box freeze
Sky Q box.
After inactivity stops responding until hard reboot.
TV says no HDMI connected.
The LED on Sky box is green.
The sky box cannot be turned off either by remote or front of unit.
Re: Sky Q box freeze
@CWH wrote:
Sky Q box.
Hi @CWH
