This discussion topic has been answered Discussion topic: No hard disc sky Q box
Message posted on 25 Mar 2024 03:28 PM
Got a message saying a problem with your hard disc drive on sky Q, tried a reset, didn't work
Message posted on 25 Mar 2024 03:31 PM - last edited: 25 Mar 2024 03:32 PM
Hi @philburslem
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @philburslem
