Discussion topic: Sky Q and YouFibre - "Failed, Remote network problem.
This message was authored by Andyboro1993 This message was authored by: Andyboro1993
Since moving to Youfibre I tend to get the dreaded "Failed, Network remote problem" I have gone through all the fixes on here, turn off tailored ads, change DNS settings, been in touch with Youfibre who said it's down to sky and been in touch with sky who said its down to Youfibre!!! I'm about to give up and throw my box out of the window....any help would be appreciated.
This message was authored by Addie15 This message was authored by: Addie15
Re: Sky Q and YouFibre - "Failed, Remote network problem.
Posted by a Sky employee
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
We are still looking to help you Andyboro1993. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
This message was authored by Clare1214 This message was authored by: Clare1214
Did you get the problem resolved please? I have just signed up to youfibre and I've started getting the same problem
This message was authored by Totalwar2 This message was authored by: Totalwar2
I having same issue with Sky Q and I never had this issue with sky broadband.Since I went to Community Fibre I been having this remote network problem.Has anyone found a fix for this.
Sky Steam Sky Boardband and Sky Moblie SKY BRING BACK NEVER MISS.
This message was authored by Subivan This message was authored by: Subivan
Having the same problem since moving to another fibre provider. The next programme in a sequence frequently fails to download with the message "
Failed, Remote network problem"
either fails at the very start of the download or at about 40%.
Any solution out there?
This message was authored by MLS11 This message was authored by: MLS11
I have regularly had the same problem since I moved to Community Fibre last month. I don't recall there being an issue while I was with Virgin Media broadband. Does Sky Q just not like very fast connections? MLS
This message was authored by JW1983 This message was authored by: JW1983
I'm having the same issue since moving to community fibre It takes.me 20 attempts to download the episode , sometimes rebooting the box "
This message was authored by AJT23 This message was authored by: AJT23
Has anyone had this resolved?
Spoke to my iSP today. It's a random fault affecting Q users. As a test I used SkyGo to test download a program that had failed on Q. It downloaded to my phone without a prob, so it's not a config problem with my router.
the ISP believes it's an issue with adverts being downloaded.
I use a point to point service and changed to a new one a few weeks ago. The old one was fine.
I don't seem to be getting this now and done nothing at all
This message was authored by rit81 This message was authored by: rit81
I'm getting this problem randomly. I'm on sky broadband. Internet is fine for everything else. Can stream from Netflix Amazon Prime and Apple TV without any issues.
The problem here is presumably a combination of Sky Q and their download service. It's on 100% Sky to investigate individual problems such as ours so they can figure out what is causing the endemic problem of episodes randomly not downloading; then once they've done that figure out how to fix. If they do indeed "believe in better".
This message was authored by Chodley This message was authored by: Chodley
It's usually caused by the ad insertion engine not connecting to its content server I believe. Some have found changing DNS to 1.1.1.1 or 8.8.8.8 helps (though the OP said they tried something with DNS with no joy)
I've got a 1Gb connection and it's fine
What's a "point to point service"?
