Discussion topic: Sky Q amber light
Message posted on 05 Jul 2025 08:29 AM
Sky Q amber light
For the last few weeks, I return home from work to find the sky box on standby (which I do the night before) but it will not turn on. I have to restart the box each time. This was never an issue but now it is happening daily! I used the troubleshooting guide but that still didn't work, so please advise.
Message posted on 05 Jul 2025 09:26 AM - last edited: 05 Jul 2025 09:27 AM
Re: Sky Q amber light
Hi @SanK
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing thisTry a Reset Settings in the Q box hidden menu.
