Discussion topic: Sky Q WiFi Issues
This message was authored by: Dazza1975
Sky Q WiFi Issues
Over the last 10 days or so the WiFi connection on my sky q box keeps dropping out every few hours and I need to reset it, including reinputting the WiFi password every time. Has anyone else had similar issues. Its been fine until recently.
This message was authored by: TonyManx
Re: Sky Q WiFi Issues
Had same problem but seemed to have solved by using extender plugs with router connected in its room by cable to one plug and the plug in the lounge connected by another cable.
However, the problem I now face is that the mini box upstairs will not connect and get error code MR102?
