Discussion topic: Technical Fault on Sky Q
This message was authored by: Quitieloon
My sky Q box is very hot and has to be restarted daily to get programmes, if not restarted then the picture either flickers constantly or comes up a technical fault.  If box is restarted then works fine for a whike
