Discussion topic: Sky Q Ticking
Message posted on 18 Nov 2024 08:31 PM
Sky Q Ticking
Hi guys.
I got sky to replace my initial 2TB box as it was creating an annoying ticking noise. I know this has probably been discussed on here many times, I was wondering whether the 1TB box would be any quieter? Or are they likely to be the same?
Cheers!
Message posted on 18 Nov 2024 08:37 PM
Re: Sky Q Ticking
@M_Smith wrote:
Hi guys.
Cheers!
Not likely to be any difference between 1 TB and 2 TB boxes @M_Smith .
Hard drive noise may vary on any box. Also consider what surface you Q box is located on. This can also cause variations in noise.
