Discussion topic: Issue with Sky Q
This message was authored by Bazmac636 This message was authored by: Bazmac636
Issue with Sky Q
Hi my sky Q box will not connect to my Sky router / Broadband which was the issue we had when the last engineer was here on 05-11-2024
Re: Issue with Sky Q
Hi @Bazmac636
Is your Sky router the Sky Max version?
Bazmac636
I don't think so it's a black router with 4 green lights along the bottom
Hi @Bazmac636
Have you completed the following procedure?
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Bazmac636
I haven't reset the router but I have tried the reset process on the sky Q box but it will not find the router or connect to the WiFi at all and it just keeps saying checking.
Hi @Bazmac636
Assume you are pressing the WPS button onthe router and not the Q box?
