This discussion topic has been answered Discussion topic: Sky Q Technical Issue
Message posted on 18 Jul 2025 07:00 PM
Was having trouble with my apps on Sky Q earlier. Rang them and they told me to reset my settings, since then nothing has worked and I'm getting a screen saying there is a technical difficulty and they're working hard to fix it. Any one else?
Message posted on 18 Jul 2025 09:20 PM
@MichaelJM1989 wrote:
Blue screen everywhere with the message 'Sorry because of a technical issue you’re experiencing a limited service. Please be assured that we’re working hard to fix the problem.' In settings my network is connected but no satellite or connection to Sky Go or my Sky Q Mini. Nothing in the menu works, tv guide etc.
Work through the following link @MichaelJM1989
You may need to repeat some of the steps you havoe[ already taken
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 18 Jul 2025 08:51 PM
							Re: Sky Q Technical Issue
Have you tried rebooting your Q box since you did the reset settings?
Message posted on 18 Jul 2025 09:12 PM
Hi there. Yes I have a few times and tried resetting my router but to no avail. Sky seemed a bit puzzled which was worrying. I hope I haven't lost all my recordings. All they could do was book an engineer to come next Tuesday. Disappointing to be without anything until then.
Message posted on 18 Jul 2025 09:15 PM
So what do you see after a reboot @MichaelJM1989 ??
Message posted on 18 Jul 2025 09:17 PM
Message posted on 20 Jul 2025 10:08 AM
Hi. Everything back working today, strangely. I was initially unable to download anything but reset router and main Sky Q box and it's fine now. Thanks for the help.
