Discussion topic: Mini box and main box not working
Message posted on 20 Jul 2025 11:11 AM
Sky main box cut out, last evening, now working, minibox not working, message says, Not connected to Sky broadband, which I am.
Message posted on 20 Jul 2025 11:21 AM
Re: Mini box and main box not working
Hi @buggerall21
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
