Discussion topic: Sky Q Switching Off and Recording Faults.
Message posted on 31 May 2025 05:49 PM
My Sky Q has been switching Off recently which reason why. Probably a couple of months now.
Today it failed to record a program which nothing other than "A Technical Fault Occurred".
When it switches off, it stops all recordings. The recordings still show as there but there is nothing there other than Delete or Remove Series Link.
Getting annoying now as this time it was F1.
I've tried a few resets, changed batteries in remote etc.
Message posted on 31 May 2025 09:31 PM
							Re: Sky Q Switching Off and Recording Faults.
have you carried out Reset Settings in the hidden menu. @SteveandShaz ?
Message posted on 01 Jun 2025 01:30 AM
Thank you, I think. I'm not in good health and all that was over my head. I'll just have to put up with it. But, thank you anyway.
